Counting stairs landing as a step in revit
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
suganesh_matrix_a540
599 Aufrufe, 3 Antworten
Hello everyone
I am trying to create stairs using an AutoCAD drawing. In that drawing the landing has been counted as a step, whereas while making a stair in revit the landing is not counted as a step, this is causing the overall length of the  stairs to increase. Can anyone tell if there is any setting to make the landing as step/riser?
Thank you
3 ANTWORTEN 3
Nachricht 2 von 4
In the stairs you have option to start the numbering with 0,1 or 2 as you want it's the "Tread/Riser start number" and the revit is counting the riser or thread according to your choice in "tread number tag" which also have options of display you can use these option to manipluate the numbering or just split each flight in a seprate stair.
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Nachricht 3 von 4
Did you actually add a landing or is your "landing" a floor level?
Nachricht 4 von 4
als Antwort auf: suganesh_matrix_a540
@suganesh_matrix_a540 wrote:
Hello everyone
Thank you
Share you stair model because Revit should count landings as steps properly.
