Counting number of People - Revit scheduling
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1129 Aufrufe, 2 Antworten
Hi All,
I'm trying to setup a schedule for the company and I believe there's no way to count the number of people in revit so I was wondering if it's possible to count the number of people via workstation table tops? Say if I have a 4 pod workstation where I used 4 of the same custom tops, are there any ways to count the number of table tops in the component once placed in the Project? Or would it be better to just use a different task chairs for the workstations in order for us to count the number of people? Unless there's a better way of doing this?
Thank you!
Thomas C
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Either of your proposals would work.
1. Workstation based:
- create different types, e.g. 4-person, 6-person, etc.
- in project, add a project type parameter "number of person" and assign it to the category of the workstation (furniture or furn system???)
- edit workstation types and enter the value for thta parameter: 4, 6, etc.
- create a schedule counting the workstations, add "number of person" as a field, format it to Calculate totals
- group the schedule by Type, uncheck Itemized every instance, and check Calculate Totals
2. Task chair based: even more straight forward.  Just create a schedule to count the chairs.
Nachricht 3 von 3
als Antwort auf: ToanDN
Hi ToanDN
It worked! I created a shared Type parameter "Number" to the workstation and calculated the totals now its working great!
Thank you!
