countertop cleanup
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
htews
687 Aufrufe, 3 Antworten
countertop cleanup
is there a way to clean up countertop common edges?  can't join them, can't change the linework unless you want to change the entire outline of the countertop to what you want and then pick the remaining edges with a detail line.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: htews
Create them as generic model families and join geometry  in project.
Annotation 2019-05-30 152009.pngAnnotation 2019-05-30 151932.pngAnnotation 2019-05-30 151918.png
Nachricht 3 von 4
FYI...if you are using the OOTB countertop...the 3D element is set to not be visible in plan.  What you are seeing is a masking region with a symbolic line for the backsplash. This is also why you cannot host sinks with voids in it from a plan view.
Nachricht 4 von 4
htews
als Antwort auf: Anonymous
Perfect!
@Anonymous THANK YOU!
Thank you,
Howard
