COUNT totals with KEYNOTES workaround
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1459 Aufrufe, 3 Antworten
Hello world.
Is there any way I can count keynoted elements?
I NEED* to use keynotes for tagging appliances and having the elements totals is also necessary.
I am looking to avoid inserting the spec values (ex: A1) in two parameters manually. (For example I would need to insert the value A1 in keynote # parameter and Model (for example) parameter to get a schedule with totals (count).
I wonder if Dynamo can make this task easier. Any clue?
Thank you world
*keynote schedule will appear in every sheet and i want only the used tags to show up. so this is a must.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Do you want "Grand Total" per sheet similar to attached image?
For instance, Keynote Numbering method is "by Sheet", and only those Keynotes visible in the Sheet View are displayed and "Grand Totaled" in the Sheet's Keynote Schedule. So basically, your using a filter (Filter Tab) to control which Key Value(s) to count, and setting Grand Total on the Sorting & Grouping Tab to display the GT count on the sheet. Additionally, under the Sorting and Grouping Tab, you can group and total like Key Values.
Nachricht 3 von 4
You can add the sum below, not next to, each key.
Nachricht 4 von 4
als Antwort auf: ToanDN
thanks toan and barthbradley
Frau (überglücklich)
great, fast and easy workaround
