Count of assembly names
6 ANTWORTEN 6
Nachricht 1 von 7
ruiterCV8G6
416 Aufrufe, 6 Antworten
I would like to know if there is a way to count the number of assemblies in a model.
I have a model with several assemblies which are exactly the same and would like to know how to count the number of these assemblies.
Anyone a suggestion for this issue?
6 ANTWORTEN 6
Nachricht 2 von 7
ralphdenhaan
als Antwort auf: ruiterCV8G6
You can create an Assemblies schedule and add Count parameter to it?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 7
ruiterCV8G6
als Antwort auf: ralphdenhaan
Hello Ralph,
Thanks for helping me on the way!
I've made the schedule and it works fine.
But I want the count only to be specific for the sheet that I put the schedule on. For example.... assembly W0.12 ==> count = 13. And not a complete list of every assembly with their numbers.
Is this possible?
Nachricht 4 von 7
ralphdenhaan
With Revit 23 / 24 you can by checking this:
Nachricht 5 von 7
ruiterCV8G6
Ralph,
You're the best!
Thanks man! Very helpfull!
Nachricht 6 von 7
ruiterCV8G6
Just a small problem with " filter by sheet" ......
The main schedule:
What is on the sheet....
Filter by sheet..... is apparently not an option in my model.
How to solve the issue?
Nachricht 7 von 7
ralphdenhaan
Filter by sheet does count the total of elements that are actual on sheet.
Otherwise you can make a filter that filters on name for example.
In your case, you want to show SP-GR 2? If im right?
In this case, you need to create a schedule for each Type.
