I have a linked structure Revit file, I want to print a sheet to pdf.
The problem I want to show the hidden wall. Hidden lines of walls visible in sheets at Revit but when exporting sheets to pdf, Hidden lines disappear.
There are two picture clarify the problem. one snapped inside Revit program and the other snapped from the pdf file.
From Revit
From PDF
Are these hidden lines or reference planes?! they look like the latter
To reveal hidden lines you need to Go to View tab on the ribbon >> Show hidden Line ... then click the element you want to show lines through the the Element which is hidden
if you want reference planes to export ...uncheck the box
I cannot recreate the issue you are having and hidden lines seem to export fine. You need to be more specific and generous with words otherwise upload the model and the link
1- Link
2-Link
3-Model
4-print to pdf
Its structure building linked to another revit file.
It is a tank containing walls under the roof.
I still cannot replicate the issue... Model lines always print in both Vector and Raster mode. It must be either you pdf printer driver or something obscuring the line when printing (a scope box a region...)
Instead of model lines, try to do one of the following
Apologies, if you can't share the models I am not able to help more
