Hey People,(sorry for my english)
I got a problem, i tried to load a Furniture family with a type catalog file, but everytime when i do it, i got an error (Could Not parse Column Header)
I exported the Txt file from revit and i add the nested family's columns but i can make it work. Also i export the txt with inches but in txt file i got larger number very high, i dont know if this is the problem . I upload the two files.
If anybody could help me that would be great. THANKS
You have invalid value in your txt file. For example this is a wrong value "1.583.333.333.333"; you can only have 1 dot in a number. Open the txt file using excel, chose formatting to be comma delimited.
Then modify the values for following columns:
| Width##LENGTH##FEET | Height##LENGTH##FEET | Depth##LENGTH##FEET | Height Seat##LENGTH##FEET | Height Arm##LENGTH##FEET | Arm Spread##LENGTH##FEET | Seat Width##LENGTH##FEET | Seat Depth##LENGTH##FEET |
Then save it as CSV format (comma delimited), then change file type to txt.
After doing so the import will work like a charm.
This response helped me.
attached is the link to the new units that are used
https://engworksglobal.com/2020/09/24/autodesk-revit-2021-units-of-measure-database-modifications/
