Creating Triangle Prism form using Generic Model Adapative template but the form (geometry) could not be created. I tried using In-Place Massing inside the model as well but that kind of form could not just be established. Is there something I might be missing?
Thanks for your help in advance.
I could create a 3D Form by selecting the boundary and using "Create Form" as 3D Triangular Extrusion was then created, i then deleted the extruded 3D face and leaves you with the Panel element
Is this what you are looking for?
@jay_colcombe @syman2000 Thank you so much for your reply. Actually I was looking for a solid extrusion as a single geometry. The reason being is to attach a material and get the volume out of it for estimating.
Here is the version with the volume. To create one with volume, you simply have to create two triangles profile and loft them together.
