Costumed Angle parameter of Curtain Wall Panel strange behaviour
0 ANTWORTEN 0
Nachricht 1 von 1
230 Aufrufe, 0 Antworten
Hello everyone,
i've been working for a while on a project which has 4 facades curtain wall panels full height.
i've had to make a costumed curtain wall panel with fixed top and bottom and in the middle part, it can open to different angles. (see video).
when i click on family type properties and change the angle it goes pretty well until i set it to 0. once i set the parameter to 0 and then click okay, exit and go back to family type to change it to 30 degrees for example the parameter fuc**es up the entire curtain wall.
now to the annoying part. once i've seen it workes at the beginning i have duplicated this family tens of times and assigned different materials on them to create an interesting facad and now i noticed i cannot change the angle. Frustrierte Smiley .
attached a video and a Revit file.
0 ANTWORTEN 0
