Corte de cajón de persiana con muro
1 ANTWORT 1
Nachricht 1 von 2
436 Aufrufe, 1 Antwort
Buenos días,
Estaba colocando ventanas con un cajón de persiana que va desfasado a cada lado de la ventana 100mm. Al realizar un vacío para que corte el muro no sé cómo hacer para que corte también ese desfase de cajón.
Adjunto imagen.
Muchas gracias,
1 ANTWORT 1
Nachricht 2 von 2
constantin.stroescu
als Antwort auf: Anonymous
Maybe this Family (Revit 2018) from BIMOBJECT can be of any use.
The problem with it is that it does not contain the Window, that's why you'll need:
  • either to make a Window Family with this Shutter Family Nested into it ( I recommend it)
  • or , at least to place it over the Window Family into the project ( this method- looks quite primitive)
  • if you place the Family on a Wall without a Window Family or other Opening, then you will need to activate the cutting Void , by using Cut command ( select the host Wall and the shutter Family and apply Cut)
Constantin Stroescu
