Corrupt Revit File
5 ANTWORTEN 5
Nachricht 1 von 6
Liam.ArmstrongHTE6T
346 Aufrufe, 5 Antworten
Corrupt Revit File
I'm currently in charge of coordinating models from different software packages, one of those being Revit. When i go to coordinate the revit files in Navisworks it says the revit file is corrupt. When i go to remove the corrupt item by purging the model withing revit and and remove item my revit file crashes. I've also ran a audit on the corrupt file and when it completes the revit file again crashes. How do i get rid of the corrupt item so i can start to coordinate the model.
5 ANTWORTEN 5
Nachricht 2 von 6
What's corrupted? Is it something in the project or the project itself? What are you trying to purge?
FYI: Purge removes unused views, families, and other objects from the project to improve performance and reduce file size. It doesn't work like AutoCAD Purge-Audit.
Nachricht 3 von 6
It is an item that is corrupt.
Nachricht 4 von 6
I get that it is an "item". What kind of "item" though? Family, System Family, Link, Import, etc.? Have you isolated it?
Nachricht 5 von 6
Hello, try to clear your warnings and see if helps. Thanks
Nachricht 6 von 6
als Antwort auf: ennujozlagam
Have you tried Audit yet? Check "Audit" when you open the file. May take awhile, but might resolve.
