corrupt file: "there are too many elements missing"
Hi all,
After excessive research I can't find a solution to this problem and I hope anyone here might have an idea.
I have one central file that I can't open due to too many elements missing. Trying to rollback, the only backup file that I can actually open is one from 2 days ago, which means loosing 2 days worth of work.
All team members working on this file use the same version of Revit (2017.2) so that is not the cause of this problem.
I also tried autodesk's solution (http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-9AFAAE6B-4107-4478-8B80-53467FE118DB) but the journal file doesn't contain any missing elements records.
I've tried detaching from central, saving backup files with a different name in a different location away from the corrupted file... still, I can't open any of them.
What I find very strange is that all backup files from yesterday are corrupted even though I was successfully working on my local file and synchronising without a problem all day and yet somehow this morning all of yesterdays backups are corrupted.
Any ideas?
Thank you in advance!
Kind regards,
Greta
