Corrupt file - Assertion failed: line 561 of UndoMgrInterface.cpp
4 ANTWORTEN 4
Nachricht 1 von 5
boostyourbim
635 Aufrufe, 4 Antworten
Revit 2018 crashes trying to open this file.
'C 14-Nov-2017 16:29:05.955;  10:< Assertion failed: line 561 of d:\ship\2018_px64\source\revit\revitdb\undo\UndoMgrInterface.cpp
Please report this to the Dev team and let me know how this might be avoided while I wait for a fix, hopefully in 2018.3
4 ANTWORTEN 4
Nachricht 2 von 5
yurikim
als Antwort auf: boostyourbim
Thank you for your posting @boostyourbim. Try this file and see if this helps.
I couldn't see the same lines as you in journal though. Did this happen after Undo command?
Yuri Kim
Product Support Specialist, AEC
Nachricht 3 von 5
boostyourbim
als Antwort auf: yurikim
Thank you for your quick reply and repairing the file!
However, I need to understand if there is any way I can avoid this corruption. If it is caused by the contents of the file or the API command I am developing, I need that resolved before I release this product to my customers.
Regards
Harry
Nachricht 4 von 5
yurikim
Thank you for your reply @boostyourbim.
You might want to check this forum to get more help on your codes:
https://forums.autodesk.com/t5/revit-api-forum/bd-p/160
Yuri Kim
Nachricht 5 von 5
dcarlson
Is it possible to get more information on this issue? We're experiencing this problem with a project on BIM360 and have been unable to resolve it. Do we need to send the project somewhere to have it fixed, or is there a way we can do this ourselves?
