Corrupt Family Cant See Family Name when Save As
6 ANTWORTEN 6
Nachricht 1 von 7
luke9R9ZN
437 Aufrufe, 6 Antworten
I am trying to weed out the corrupted families in my project using the save as family. Workflow detailed here -
https://forums.autodesk.com/t5/revit-architecture-forum/how-to-find-corrupted-families/td-p/9044163#....
When an error window popped up, I used to be able to see the name of the family next to the loading bar in the bottom left corner of the main window. In the current version of revit the name of the family is covered by the loading bar and cancel button. Has anyone seen this before/has a workaround? I can't see any reference to family in the html error report. Thanks in advance for your help
Revit 2022
22.0.2.392
20210224_1515(x64)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: luke9R9ZN
Nachricht 3 von 7
Change Windows Display Scaling to 100%.
Nachricht 4 von 7
luke9R9ZN
als Antwort auf: barthbradley
Hi @barthbradley  Thanks for the suggestion. Yes, audited the file with no errors. Still the same problem when doing the family save as
Nachricht 5 von 7
luke9R9ZN
als Antwort auf: ToanDN
Thanks for the suggestion, I've was at 125% scaling. I switched it back to 100%, restarted, still getting the same problem.
Nachricht 6 von 7
luke9R9ZN
I tried this on another machine in the office and get the same UI problem
Nachricht 7 von 7
Try Autodesk BIM Interoperability Tools > Model Checker.
