I'm doing a composite floor, steel beam& joist supporting a concrete slab. I am not sure how to do STEEL FRAMING FLOOR, (2) I am also not sure how to do the CORRUGATED METAL DECKING connected with CONCRETE SLAB. (1)
TQ,
Jiner
(1) corrugated metal deck with concrete slab
(2) steel frame underneath
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I tried your method, it is only showing in section but not in 3D.
How to fix it up to show in 3D?
see, 3D dont have corruagted profile.
Jiner.
The decking only shows in one direction and with Detail Level set to Med. or Fine.
...oh! Missed the "3D" part. The Decking is a 2D Profile only.
If you want a deck that is Visible in 3D, you need to model it. Joined Beams System would do the trick.
