Hello all,
I created a Curtain wall corrugated panel. I loaded it in the project below, attaching it in the basic wall. How can I create an opening in the corrugated panel for the door?
Also how can I have the corrugated panel exactly in the same lenght like the basic wall?
Thank you in advance!
To make this panel flex between curtain wall grid lines, you need to create an array (the type of an array that is defined by the position of its last unit). Array the extrusion shown below. Lock the array to the reference planes. You will create an opening by adding grid lines and positioning them next to the door. So, the opening will be created between two grid lines and the panel defined by those grid lines will be empty.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
@mairh_tsek: You might want search this forum for "Corrugated". I think you'll find plenty. I know I've posted a few RVTs and RFAs over time for others.
