Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Corner wrapping downpipe
1 REPLY 1
364 Views, 1 Reply
hi all, is it at all possible to create a downpipe that wraps around a corner?
we use them from time to time on zero lot blocks when we have a garage with a gable end at the back.
Here is an image to help explain. Thanks.
Tags (2)
1 REPLY 1
I think I've solved that one myself. I've used a floor based downpipe then rotated it 45 degrees. It has the desired effect 🙂
floor based DP 45 degreefloor based DP 45 degree
