Corner Trim on Exterior wall
3 ANTWORTEN 3
Nachricht 1 von 4
420 Aufrufe, 3 Antworten
i am triming the wall but its no t trimed properly picture is attached please advise how it can be solved1.png
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
I guess, either of the walls are not allowed to join. Try this. After you select the wall on top, right click on the wall end (the blue dot) and allow join. Separate them first then try trim again. Do this for bottom wall if it doesn't work on top wall.
Nachricht 3 von 4
If the above doesn't work, try going to 3D view and ensure there are no other walls or components obstructing the wall join.
If you still have problems, let us know with more information possibly a 3D view
Nachricht 4 von 4
Grip edit one of the wall or use the Wall Joins tool under Modify palette.
