Dear devoted Revit Users,
I have a quick question about copying of structural foundation.
When I tried to copy, by dragging down it below the original foundation on elevation view,
it was overlapped in the same position then showed the warning below.
I can move after it is located the same place and I can also copy above the original foundation but not below.
Why??
If anyone can tell the reason for this behavior I would appreciate it.
Revit has a lot of mystery ![]()
Yuki
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
To creat it below the original, you first need to creat a level under level 1 set at 0. It will work.
..just give the copy a negative offset to remove warning. You shouldn't need additional datums -- unless you prefer to do it that way.
Thank you for your comment.
So it is normal behavior of structural foundation, isn't it?
I mean that the copied foundation is automatically attached to the closest level.
I just wondered about the different behavior of this category, that is all.
Thank you.
@ysautodesklover wrote:So it is normal behavior of structural foundation, isn't it?
Yes.
