Copying Family Types
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1863 Aufrufe, 3 Antworten
Hello just wondering if there is any way to copy the family types table from one model to another. I have tried to use copy family parameters add inn but i can only get that to copy the  parameter name over not the value which i also need copied over also it dose not copy the different types over . Do you Guys have any other ideas on how to do this i tried to export the family types but could not get them to import into my other model.
""" i would like to copy all the highlighted items shown in picture attached''''
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Save As and copy paste the model of the family in?
Nachricht 3 von 4
als Antwort auf: ToanDN
That would work but it wont let you copy models in if they aren't hosted to the same thing.  because the model i want to copy the the family type data from is a wall based and the one i want to paste it to is a  non hosted model
Nachricht 4 von 4
Oh, you can convert a wall based family to a face based, then edit the face based to get rid of the face to make it a non host.
http://www.jarodschultz.com/revit-wallface-based-family-trick/
