Copying attached detailed group
3 ANTWORTEN 3
Nachricht 1 von 4
danaDGX4M
772 Aufrufe, 3 Antworten
I have a model with a group of floors and walls, that appears in a few levels. I want to add detailed group of texts and dimensions, so it will show in all the groups. I tried to creat attached detailed group, but it won't appear in all the groups (only where I created it), and I can't copy it between the groups.
What am I missing?
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: danaDGX4M
@danaDGX4M
The attached detail group does not get associated with all the placed and new instances of the model group...this behavior allows for the following:
  • A model group can have more than 1 Detail Group attached to it.
  • Same detail group can be attached to more than one model group
If all your Model Group 1 instances have the same Detail group, from the browser >> Right Click the Model group and select all instance >> On the Ribbon/Modify tab - Click Attached detail group >> Check the box for the detail group you want to attach
Nachricht 3 von 4
danaDGX4M
als Antwort auf: RDAOU
Thank you for the quick reply! I tried as you suggested, but received the following message:
Can't make change to Group "2" with more than one instance. To resolve: Ungroup and Group again under a new name. Edit and make change, then change all instances of the original Group to the new Group.
What am I doing wrong?
Nachricht 4 von 4
RDAOU
@danaDGX4M
It is hard to guess what is in your group 2? can you upload a file or something to look at
