I'm trying to mess around with assemblies, but I can't seem to place another instance of an assembly without getting this warning: "Edits caused an assembly to match an existing assembly type and inherit a new name." But there was no edit, and it doesn't even create a new type or change the name. I've seen other posts about this issue but I'm using Generic Models not a Face Based family or anything that could possibly change on placement. Has anyone else come across this issue before?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I recreated this issue using an In-Place component family. The change in name is referring to a new Generic Model family being created. Since In-Place families are one of a kind normally, when a copy is made of it, outside of the in-place editor, it gives it a new name. If you copy an assembly, this is exactly what is happening - a copy of the in-place family is created. Check your Project Browser > Families > Generic Models for the other families being created.
Technically, there is nothing 'wrong' with this, but if you have many copies of this assembly, you will fill your model up with many copies of the generic model. Also, if you edit the GM inside the assembly, the other copies of the assembly will not update, since they actually contain a different family than the original, which ultimately will result in a second assembly being made.
So, best not to use in-place components inside an assembly.
Meaning...
There will be a time when you find out that copying an assembly or placing a new instance of an existing assembly will generate a new assembly. And Revit of course will prompt you that a new assembly with a new name has been created...That's when you will ask "BUT WHY...I want to copy the same assembly"...this is where the answer would be what @ToanDN suggested...Groups is what you are looking for not Assemblies
Thanks for the explanation, I guess I thought assemblies were intended to have multiple instances. The reason I made an assembly to begin with was to test the part list.
Then you are on the right track...when you work with parts, you need assemblies not groups. And when parts change you get new assemblies.
Example: If you try the Precast extension, you will notice that they are assemblies not Groups.
The ‘Assembly’ System of Revit works like a special Family, which can automatically create symbols by instances, Assembly <=> Family, AssemblyType <=>FamilySymbol, AssemblyInstance <=>FamliyInstance; but in revitUI can’t directly edit AssemblyType, we can only edit an AssemblyInstance and Revit will automatically recognize/arrange its Type(Symbol).
