Copying and pasting from one version of revit to another
5 ANTWORTEN 5
Nachricht 1 von 6
ajhN9T6C
7495 Aufrufe, 5 Antworten
I was wondering if anyone knew if its possible to copy a detail line from Revit 21 into Revit 22? I've tried copy to clipboard and it works in the same version, but when I open my Revit 22 project, it doesn't give me the option to paste it. is there a way round this? or is it not possible between two different versions?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: ajhN9T6C
Open a copy of the 21 file in 22 then copy paste.
Nachricht 3 von 6
ajhN9T6C
als Antwort auf: ToanDN
thanks, I tried this but still no luck unfortunately
Nachricht 4 von 6
I think you misunderstood @ToanDN - or we're misunderstanding you. If you want to copy content from 21 to 22, UPGRADE 21 to 22, and then copy/paste between them or use Transfer Project Standards or load one RVT into the other RVT.  So on and so forth.  "Upgrade" is the operative word.
Nachricht 5 von 6
ajhN9T6C
als Antwort auf: barthbradley
Sorry yeah, I realized after I responded what he meant. I got it to work. thanks very much for the help.
Nachricht 6 von 6
lucdoucet_msdl
@ajhN9T6C
Another suggestion to quicken the upgrade process when dealing with a large RVT project file (or on a slower PC), is to export out the only the elements needed:
  1. Create a detail group with the 2D line in question in the earlier version;
  2. Save the detail group out as a RVT project from the earlier version;
  3. Open and upgrade the smaller RVT detail project file in the later version;
  4. Copy and paste to your later version version RVT project.
Hope this helps,
-luc
