COPY why not multiple? as default
4 ANTWORTEN 4
Nachricht 1 von 5
400 Aufrufe, 4 Antworten
Gawd it is up there on the list of annoying aspects of the default settings <which we are all waiting to be able to intelligently edit to suit our own way of doing things> . . .
But why oh why would you set the default option on copy to single? This is truly annoying to have to go up and select multiple every time one restarts revit. And yes it happens to templates too!
Oy vei.
Still cannot live without Revit tho . . . in spite of the truly maddening defaults.
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
syman2000
als Antwort auf: Anonymous
Revit 2022 seems to fix this. If you copy and select multiple, it will remember the last command. When I close Revit and reopen, it remember my last command.
Nachricht 3 von 5
als Antwort auf: syman2000
In the immortal words of Leonard Cohen . . . "hallelujah". They always claimed that was their metaphor but some actions do some do not.
Wondering . . . did they make all windows capable of resizing in this new release? Also do you know if there is a way to setup transparency to a category (like topography surface ~ i am constantly having to adjust each section base so i don't have opaque ground (so i can see the extent of footings). . . ?
Mahlalo for the good news! I dare not upgrade as i am swamped in my wee Yurt office with exciting new projects! Everyone of them has a splendid Pacific ocean view! woohoo
Nachricht 4 von 5
syman2000
I assume you want to know if Revit remember the screen window size when it is doc or place on secondary screen - nope. For topo, the default is set to opaque and no way to change it to transparent unless you change the category. You can change it to wireframe so it shows thru and see thru the topo.
Nachricht 5 von 5
Opaque is horrible in sections :vor_Angst_erstarrtes_Gesicht:
