Copy Text
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2104 Aufrufe, 3 Antworten
Copy Text
Hello. I am trying to copy and paste a text with a leader within one view and
there is an error message that says is not visible in the view.. Not as simple as it seems.
Help appreciated to solve this problem. Thanks.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
For now, just hold down control and select and drag. That is how you can copy and paste much faster. If you purge your file, delete all cad links revit links and upload it so I can take a look maybe i can help you
Nachricht 3 von 4
Have you tried to disable the annotation cropping of the view as the message suggested?
Nachricht 4 von 4
trevor.clarkM88RA
I was having the same issue with text objects: cannot copy & paste text within the same view without receiving the visibility error, but could use "CO" copy command or Ctl drag. The problem was related to the fact that the view was rotated with an annotative crop and the text was pasting in the original un-rotated orientation putting it outside the crop. Turned off the annotative crop as suggested and the issue because apparent.
