Is there any way to copy rebar tag from one file to another including the instant parameter. i.e. for rebar tags I am using the following label (Schedule Mark x Quantity-Type Name @ Spacing Rebar Number Comment) which will give me result like (2x10#6@ 1'-0"-OC-2024 EF) but if I copy the tag to another drawing it won't copy Schedule Mark & Comment.
You can try to transfer project standards from your existing project to new project. This option you will find in mange tab.
the normal instance parameter in TAG is come from the element not from tag,the tag can not control the normal parameter type or instance share or not share , the element control the parameters,except the calculated parameter,
So i think your answere is No,but you can copy the schedule or Legends from project to another project.direct copy them from sheet to sheet.
