Copy rotate
1 ANTWORT 1
Nachricht 1 von 2
yes_and_no
183 Aufrufe, 1 Antwort
Copy rotate
You can "create similar" and use space bar to rotate.
I use control and drag, then rotate.
The 2nd method is faster for me.
Is there other faster way doing this ?
I remember the autocad lisp-time, that can be done in one key stroke.
1 ANTWORT 1
Nachricht 2 von 2
alan.johnson7YLND
als Antwort auf: yes_and_no
I don't know if it would work for you but there is a Rotate /copy option
So as you rotate an element it creates a copy.
