Copy Project Parameter
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
PhilvK
1184 Aufrufe, 2 Antworten
I have a parameter in a Schedule A that I would like to use in Schedule B. The parameter is listed under Project Parameters, and therefore is supposedly is 'available to elements in this project'.  I can't however find a way to get the parameter into Schedule B - do I have to re-create it?
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: PhilvK
@PhilvK
Is it a Project Parameter or a Calculated Value/Parameter?
If Schedule A and B are for the same element category then that parameter could be a calculated one (then you have to recreate in schedule B.
Otherwise, Schedule B must be for a different category... Check which category of elements is Schedule A is for for, then from Manage >> Project Parameters >> Pick that parameter from the list and click Modify >>> on the Right Hand side (add the category of the elements in schedule B)
Nachricht 3 von 3
PhilvK
als Antwort auf: RDAOU
Got it...thanks!
