Copy-paste at shared coordinates / different projects
RECArchi
RECArchi
Hi everyone,
I have 2 projects, a site model and a building model, with different Internal Origins in each file.
The 2 models share the same coordinates system (Building is linked "at shared coordinates")
Question : Is it possible to copy-paste elements from the building file to the site model "at shared coordinates" ? I think Revit always uses Internal Origin when it comes to copy-paste.
Thank you in advance.
kadmonkee
not sure, but each element / component has its own origin base point.
so I would just do a copy to clipboard paste operation and place things as needed.
good idea though.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
syman2000
Why not link in the model by shared coordinate first? Then highlight the object in the link, copy and then paste in same place. It should place the object at that same spot.
What about Relocate Project?  Move the IO to the SP?
Help | Relocate the Model | Autodesk
RECArchi
Hi @syman2000 ,
It works perfectly 😀, sorry I did not think of this trick. I mark this thread solved.
@barthbradley : No I don't want to move the IO or relocate project, everything is fine in my projects. I almost never move IO (which is useless in projects).
Thank you all for your replies.
Sincerely.
