Copy Objects Between Design Options
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
steve
3205 Aufrufe, 2 Antworten
Re important something from one design option to appear in another. Importing a facade.  I want to import a facade from Alt-1 to Alt-4.  the facade option exists in Atl-1.
this video is probably the easiest way to understand my question that has me baffled. ...  https://drive.google.com/a/designbuildllc.com/file/d/1vJPWB8Uk_vd_pTo233G14kYLexBau5f5/view?usp=driv
  1. I have deleted the entire facade from alt-4.
  2. I make alt-1 the "primary option".
  3. i display the "main model".
  4. I deleselect "exclude options"
  5. no matter what I pick of an element from alt-1 (and the info pop-out tells me its in alt-1) from the facade that exists in alt-1 and NOT in alt-4 and select just to put it in alt-4 (where it does NOT exist
    1. https://drive.google.com/a/designbuildllc.com/file/d/10GtUAz9I_mt3b-WpL-V4MA9en3Dvg4oe/view?usp=driv...   ....
  6. the error message tells me I can't put it there.
  7. why not?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: steve
- Select the elements you want to copy, CTRL+C
- Change active design option to the target one, paste aligned
But if the elements are supposed to be in every Design Option then they should just be under Main Model.
Nachricht 3 von 3
steve
als Antwort auf: ToanDN
Of course!  Perfect,  thanks.
