When I use copy / monitor for an MEP link in Revit 2022, I am unable to select any fixtures within the MEP model. I can select levels. Batch Copy and Coordination Settings are unavailable.
This is what it looks like
This is what it should look like:
Gelöst! Gehe zur Lösung
Gelöst von Caleb23TDS. Gehe zur Lösung
Perhaps you need to reset Revit UI.
I don't think this is the issue. This is affecting multiple users. This also appears to be specific to Revit 2022, as I'm able to copy / monitor on other projects in other versions.
I have no issue in Revit 2022.1. Are you saying it happens to all projects in Revit 2022 or just a specific one? Maybe update to the latest 2022.1 build.
I found the solution for anyone else that may come across this article with the same issue:
Within the User Interface options, all tools should be enabled under the systems tab:
