why I get this error when using copy monitor?
[..]current file is hosted and cannot be moved automatically by Copy/Monitor. Use the Move command to relocate the fixture in the host file as required.
Both Families (one in link, and one in File) are work plane based.
the one in the File, is not hosted to anything, yet I get this error.
Any ideas what I have to change in the Family to avoid errors like these ?
See actions you can take: https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-2593470B-FBC9-49CC-9962-664D508B2B91
If the family you're trying to monitor is hosted to a work plane in one model and isn't hosted in the other model, this can lead to issues.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
I have read all the actions and errors. This is the error I am facing: https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-87F63D98-3A67-446C-8A09-65078C5C9E87
this topic does not answer the most important question - why is this happening?
I have concluded that this happens because both families are 'Work plane based'.
When I uncheck that, I can move them.
The Action Page states that: "If the fixture in the host model has been hosted on a surface using the Pick New Host tool [..]". None of the families are hosted on surface. They are hosted on reference plane, so this seems like a bug to me.
How can the copied family in host model can be hosted to the surface (using the Pick New Host) if I just copy/ monitor the family from the link model? Link model -> Copy/Monitor Family -> Family is placed and monitored.
