Copy/monitor: categories and types to copy
7 ANTWORTEN 7
Nachricht 1 von 8
cbt990
521 Aufrufe, 7 Antworten
Is it possible to specify only some original types to copy?
Revit is amazing
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: cbt990
Sure, but it ain't as fast and easy has just changing the monitored instance directly in the Project.
Nachricht 3 von 8
cbt990
als Antwort auf: barthbradley
I think this is what I was trying to do.
But when I click "Finish" the elements aren't actually copied. How do I execute the copy?
Revit is amazing
Nachricht 4 von 8
Nachricht 5 von 8
Nachricht 6 von 8
cbt990
Not quite, I think. I selected the desired elements and copied them. I know I copied them because when I try to copy again, it says:
Do I have to stop existing monitoring to get the copy to "take effect" I don't actually see the copied elements
Revit is amazing
Nachricht 7 von 8
Not directly, but you can always assign the types you DON'T want to copy monitor to a specific type in your model, finish copy monitoring, and delete all elements of that specific type.
Nachricht 8 von 8
Hard to guess.   Sounds like they are copied though. Maybe some visibility override is acting on them.
