Hi all. I have to change instance parameter data for around 20 sheets. All I need to do is, changing sheet information for all sheets that I created from scratch. I want to fill relevant parts of instance parameters as automated task. I can fill one sheet manually then copy all these information to sheets that I can choose, but here is the question;
How to do that? (Dynamo, plugin or maybe Revit itself can do it?)
Thanks for your all messages in advance.
Please see SS below.
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Select the sheets then type in the information in the parameter field
If you need more sophistication then indeed Dynamo can be an option.
Louis
Please mention Revit version, especially when uploading Revit files.
Might be easier to streamline this task through a Schedule. Food for thought.
This is a partial snapshot of the Dynamo method I'm currently using. The input nodes are set up so that they display in Dynamo Player. This allows a non-technical user to do the sheet setup work.
What's not shown in the screenshot is just filtering the sheet list by trades. You can expand with things like DataShapes for a UI so that you can do drop-down menus for each trade (large organization maybe with a staff list maybe?).
Looking back I can't say it actually saves all that much time for small companies versus the project browser or schedule filter methods, it's just another way to present the choice of typing in the information. It may be time-viable if you're pulling in a lot more information than just designer initials, or if you're pulling pre-existing information from a spreadsheet.
