So, I was wandering what is the fastest way to copy 2D references like identification notes, dimensions and basicaly all the informations that the first image attached this post contains, from this elevation to another one created on a different floor. Both showcase the same custom furniture (generic model), but the second one lacks the touchable screen panel. I tried to copy the notes, it seems to work but doesn't seems to be in the same orientation on the x-y axis. The dimensions don't follow up because I don't wanna copy the 3D model and those referes to that one so I understand, but I was wandering is there a more efficient way to make this process easier than tagging all the view again.
Just curious to know your tips to accelerate your workflow even if it is not related to this particular question, from similar drawing between floor plan, section etc!
Maybe this is a job for Grouping. Create a Model Group with a Detail Group and then Attach the Detail Group to the second View's view of the Model Group. Get it?
Have you tried copy to clipboard and then paste > Aligned to selected views
Hi @fabouchardcoteS66GH
Thanks a lot for posting your question to the forums! Have the solutions suggested by @barthbradley @alan.johnson7YLND helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
