Copy cover sheet from another project
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
hliS658H
494 Aufrufe, 4 Antworten
I want to copy a cover sheet from another project, I use inset from File > insert views from file, but from the list of sheets, I don't see the cover sheet, even after changed the sheet name number, it just doesn't show up. Are there any settings there that prevent a sheet to be inserted?
4 ANTWORTEN 4
Nachricht 2 von 5
Alfredo_Medina
als Antwort auf: hliS658H
Most likely the cover sheet that you're trying to copy contains at least one model view.
Nachricht 3 von 5
Are there model or legend views on the sheet?
Nachricht 4 von 5
hliS658H
als Antwort auf: ToanDN
I see - Yes, there is a 3D perspective view there.
Why would legend view also cause issue? Isn't legend view draft view?
Nachricht 5 von 5
Alfredo_Medina
Just Revit's rules. Only certain things can be transferred using this method. Legends is not one of those things. See higlighted note:
