Copy assembly creates new assembly
2 ANTWORTEN 2
Nachricht 1 von 3
asaundersZX5X6
1020 Aufrufe, 2 Antworten
I am working on a project with precast solid deck slabs for a parking deck and have created assemblies for each piece to create shop drawings. Some of the assemblies are identical but I am having issues copying the assemblies. Every time I go to copy the assembly it creates a new assembly and I get a warning message that state the following:
"Edits caused a new assembly to be created."
Note that the slabs are at different elevations and they are also sloping in one direction but the slope is constant across the deck.
I'm unable to determine what is causing the edits that results in the creation of a new assembly.
Can anyone please offer some advice as to what might be occurring and how to get past this?
Thanks.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: asaundersZX5X6
Hello @asaundersZX5X6,
This happens when you create a copy of assembly with two or more naming category options existed and these assemblies for some reason are being joined together.In this case, the revit will create a new assembly type. But when these assemblies joined with identical similarities from being joined the assembly name will remain the same from the existing assemblies.
Nachricht 3 von 3
asaundersZX5X6
als Antwort auf: Anonymous
I'm not sure that this is the case for my situation. All have the same naming category of "Structural Framing".
Thanks.
