Copy assembly between projects
javier_cortesYHQ5L
javier_cortesYHQ5L
HI,
Is it possible to copy an assembly from one project to another? How is it done, or what would be an alternative solution to copy from a native file to a docset file?
@RDAOU @ToanDN
Basam.Yousif
Did you encounter an issue when copy\pasting into another model?
What is a 'docset file?'
Do you have a sample model to share?
javier_cortesYHQ5L
I've a file only for documentation, which contains only the models links used to create sheets, and I call this file the "docset" (the project is very large and consists of several linked models). I need to create a curtain wall legend, but I only knows the curtain wall assembly process in order to document the curtain walls. Is it possible to copy these assemblies from the native file to the model called "docset"? Is there any other method to document the curtain wall modulation?
