Copy and paste door
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
4873 Aufrufe, 2 Antworten
Copy and paste door
Hi, all.
I tried to copy and paste this door to other wall.
But this door always move with wall and
says "Can't place inserts outside of hosts. These elements won't be copied."
Only this door cannot be easily copied.
Anyone familiar with this problem?
Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Select the door and Create Similar from the Ribbon to place the same door in a different wall.
Nachricht 3 von 3
Corsten.Au
Hi
Any revit family which requires HOST, cannot be placed without the host
( example Doors ( Wall based ) , Window ( Wall based ), Roof Fascia ( roof based ), etc )
there are two easy ways to copy the door.
1. place the door, using create similar, or new door, and change it to required type.
2. if you want to move the existing door to new wall, then Select the door, and " Select a new host "
so that all the parameters of the doors remains the same i.e. mark, type, number etc...
cheers!
Corsten
Building Designer
