Copy a plane from structural plane to floor plan
7 ANTWORTEN 7
Nachricht 1 von 8
yu85.info
378 Aufrufe, 7 Antworten
Hi, I have a model with a linked architecture file. I have created a planed view but realized I draw a plane in the Structural plane and I want to copy it to the Floor plane. Is there a way to do it? I have attached a PS
Thanks in advance .
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: yu85.info
Do you mean that you copied a Link Level to your Project and created a Plan View for that copied Level, and then placed a bunch of stuff on that Level?
Nachricht 3 von 8
yu85.info
als Antwort auf: barthbradley
exactly what you wrote. Now I want to take all this bunch of things and copy them exactly to the "FLOOR" plane.
Thank you
Nachricht 4 von 8
Copy Monitor.
For some, you can TAB copy paste aligned.
Nachricht 5 von 8
Thank you
Dang!  So, you want to move everything from that Level to another Level.  Depends on the elements. Changing Host Level(s) through Element Properties is one way. Clipboard Cut/Paste between Levels is another.  I could go on, but suffice to say, it depends. I would probably delete the level and inspect what warnings that get thrown to see exactly what issues I need to mitigate.  Then undo delete - or leave it deleted - and move forward with the needed "clean-up" work.
Nachricht 6 von 8
yu85.info
Thank you but I do not want to copy from one level to another. In the same level I wish to copy from the Structural plane to the Floor plan. Like in the PS attached.
Nachricht 7 von 8
You can't.
BTW: this is not what I described initially and what you confirmed.
Nachricht 8 von 8
yu85.info
Ok, I appreciate your help.
