Copied windows do not show on elevation when Realistic, etc.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
octavio2
409 Aufrufe, 3 Antworten
Existing copied windows on the south elevation copied to the north elevation are not shown on the building north elevations when the elevation is se to "Realistic", "Cosistent Colors", etc,, but they show when the elevation is set to "Hidden Line", so the windows are there positioned.   (The show on the south elevation OK, this just happen on the north elevation to where they were copied).
What is the reason for the no show?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: octavio2
The window does not cut the wall. Look at a 3D view and see. What are the phasing of the window, the wall, the view?
Nachricht 3 von 4
octavio2
als Antwort auf: ToanDN
everything is set now to "existing", since the exterior existing model is being drawn.
Nachricht 4 von 4
octavio2
The windows were set correctly to "existing" phase, but the elevation was set to "New Construction", so that is the reason for the windows no shows.  When the elevation was set to "existing" to agree with the phasing of the windows and of the walls, the windows appeared.
Thanks!
