Hi - I have two different mullion profiles. One is an interior vertical profile and the other is a head and sill profile. Is there away to cope one to the other or provide a void detail within the profile family or similar.
Thank-you!
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Are these curtain wall mullions? No, they won't cope/miter. You can model such conditions into a panel family but it gets complicated quickly if your panels have any corners that are not 90 degrees, only system panels support that condition. Generally the intent is to model mullions at a macro level and use details for the micro but I get the desire to model the joints so they can be more realistic.
Steve Stafford
hi
This feature is available in Revit 2025 and there are no lower versions.
https://www.youtube.com/watch?v=6xDROANKaHo&t=6282s
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-3D7247D9-BC7E-4E2A-A604-3068CDFC4861
