Coordination model shows up on only some computers
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
LyleHardin
2047 Aufrufe, 9 Antworten
On my computer, the coordination model shows just fine everywhere it should.
On another computer, same file, it only shows on the 3D views and not in any of the 2D views.
Checking Revit versions now. I notice he's on 2018, while I'm on 2018.2.
I'll report back soon. Just posting this in case there's something else going on or if others have this issue.
Other Coordination issues are brought up in this thread, but it's not what's going on with us.
https://forums.autodesk.com/t5/revit-mep-forum/revit-2018-linked-coordination-model-nwd-not-visible-...
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: LyleHardin
I have the same issue too.. It only shows up in 3d view but not in 2d view..Is there a solution to it?
Nachricht 3 von 10
Sahay_R
als Antwort auf: Anonymous
Sounds like an update to 2018.2 is called for.....
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 10
LyleHardin
als Antwort auf: Sahay_R
Ah. Sorry, I never reported back as I had indicated...
Upgrading to 2018.2 fixed it for us.
Nachricht 5 von 10
kyle.vl
I am having a similar issue. The coordination model works great on a couple computers, but on a few machines, it only shows up in a 3D view. I have also noticed that when a section box is applied to the 3D view, the coordination model disappears. A couple of the machines were already on 2018.2, and I have upgraded the others to 2018.2 as well, but they are still having issues. Now one of the machines that was working correctly is having problems.
I have run out of ideas, any suggestions would be greatly appreciated.
-Kyle
Nachricht 6 von 10
als Antwort auf: kyle.vl
For me..updating REVIT to 2018.2 helped. But my coworker also updated to 2018.2 but he still has same problem..For my coworker..nwd and nwc both does not show in 2d views but shows in 3d view.
Thanks.
Nachricht 7 von 10
Updating my REVIT to 2018.2 helped for me. But for my coworer..it did not help..he still has same issues even when on REVIT 2018.2.
Thanks.
Nachricht 8 von 10
CharlieVanRossum
I am running Revit 2018.3, and I have the same issue with the Navisworks coordination model only showing up in 3D views and not in plans and sections.  I seem to only have the issue with a certain navisworks model, because I tried a different navisworks model from a different project and it showed up in 3D, plans, and sections.  Has anyone figured this out?
Nachricht 9 von 10
Anybody find an resolution to this issue?  Still having the same problem where coordination models only show up on some computers.  We are all on 2018.3.
Nachricht 10 von 10
Never mind, I tried re-linking from the other computer and it worked for both.  Weird...
