Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi fellas!
Can someone explain what "Reconcile" actually does?
It seems that I can use this for every link, afterwards I'm able to choose local or shared coordinates.
Not 100% sure if I'm using it the right way (having all files on BIM360 though, so I guess coordinates in the linked file are locked - as it sais?)
Thanks in advance
Solved by Marcus.Isacsson. Go to Solution.
Solved by ToanDN. Go to Solution.
In that context, it means you will let Revit to modify the model coordinates system to match the acquired shared coordinates from the link.
Shared COordinates and Shared site on Construction Cloud hosted model is a long painful process...
See below Link for the acquire process BIM 360
See below Discussion on the same topic with some clarifications on why it is what it is
