Coordinates in plan view is different than coordinates in default 3d view
diesellam
diesellam
In this particular Revit file, when I'm in the plan view, I insert the DWG file that has the 2d grid line (Auto - origin to origin), it aligns perfectly.
But when I switch to default 3d view, and insert the same DWG file (Auto - origin to origin), and it doesn't align at all, why?
This has never happened to me for the other Revit files I worked with before.  Any idea?
Thanks in advance.
OK, I just realized my viewcube doesn't quite align with compass, see attached.  Could it be the reason causing the misalignment?
As you can see, the "N" is towards Northwest, north true North.  How can I reset that so it's true North?  The rotate north option is currenty grayed out.
diesellam
Forgot to attach files earlier for this post.
This is the link to the Revit file and the 2d DWG file, see below:
https://www.dropbox.com/sh/q39dyem9v8fmovl/AACijjm4Yd7tr9K_GT-Kru_va?dl=0
diesellam
Still waiting for the answer....
