Coordinates between IFC and Revit
3 ANTWORTEN 3
Nachricht 1 von 4
marco.defina
319 Aufrufe, 3 Antworten
i found some troubles workinf with IFC...When i import an IFC file i loose some informations of the location (coordinated or altitude or rotation).
Here an example. I created a simple model, i exported in IFC with shared coordinates, after this i opened the IFC and i lost the altitude...Why? I do something wrong?
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: marco.defina
Exporting from 3D View?
Nachricht 3 von 4
marco.defina
als Antwort auf: barthbradley
In my test yes! I don’t know for the IFC that i receive from architects...
Nachricht 4 von 4
marco.defina
The same exporting 2d view...
