Coordinate filters similar to AuytoCAD?
New user so likely a case of PEBKAC.
When drawing in AutoCAD I make pretty extensive use of the .x .y .z filters to place objects, text etc in place relative to existing objects.
e.g. an operation like - Pick object, [MOVE], pick mid snap, [.x], pick mid snap of wall line, [@]
to align an item with the midpoint of the wall.
Is there a similar function I'm not seeing in Revit?
RobDraw
You can find some interesting stuff by doing a search for Revit coordinate systems. What you won't find is any filters for them. Revit uses something very similar to AutoCAD's object snap tracking.
Rob
Yes! You're talking about snap from.  I use that a lot in AutoCAD as well. It's one of the things I miss most when using Revit.  Unfortunately, there is nothing like it in the Revit "toolbox".
Here are all and only options offered in Revit.  Mid-between-two-points is not there unfortunately.  I just created an adaptive family with divided points so that I can snap to a mid, a third, a tenth, anything division between two points.
