Converting mass face to roof
4 ANTWORTEN 4
Nachricht 1 von 5
318 Aufrufe, 4 Antworten
Any chance I can convert this face to roof without simplifying it?
Because right now all i found is that this geometry is too hard for revit to understand.
Making walls not an option here.
Thanks for your opinions.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Why is wall out of the question?
Maybe just insert the Mass into an In-Place Component with Category Roof and assign a Material to it.  Obviously, you'd need to hollow it out first.
Nachricht 3 von 5
Can you share the mass?
Nachricht 4 von 5
als Antwort auf: ToanDN
Thank you guys !!
Finally found a solution to this with Dynamo.
Tried it and it worked.
Anyway thanks.
Nachricht 5 von 5
Post the dyn routine.
