Converting IFC elements into native Revit elements (e.g. IfcWall → Revit Wall)
IntYo189
IntYo189
Hi everyone,
I'm currently working on an MEP project in Revit, and I regularly receive IFC files from the architect. I would like to know if it's possible to convert these IFC elements so that objects like IfcWall become actual native Revit walls (Wall), rather than staying as generic IFC elements.
The goal is to be able to place openings/reservations or use other modeling features that require native Revit objects.
Has anyone done this before or can recommend a method or plugin to achieve this?
Thanks in advance for your help!
azad.Nanva
When you import the IFC file Revit make a file same the name with ifcname.ifc.rvt
open this file in revit.
IntYo189
Hello, thank you for suggestion. I just linked an IFC and saved the file but unfortunately i dont have such a file with ifcname.ifc.rvt
azad.Nanva
You should have one,Revit made this file,but if in any reason you don't have one so you can open the IFC direct in Revit By OPEN->IFC :
RDAOU
@IntYo189
You have two options:
Option 1: Instead of linking the IFC, Open it. This is convinient is the IFC was originally created from a native Revit Model.
  1. Go to File Menu
  2. Open >> IFC
  3. If it is an IFC generated from a native Revit,
    • most of the elements would retain their original form/system families (example: Walls)
    • Other elements would be imported directshapes into the relevant catagory (example: roofs)
    • You can place inserts and openings in both
  4. If it is an IFC was not generated from a native Revit model (example: from Archicad),
    • The elements in this model would be noneparametric directshape components (non-native components - ie: you wont be able to use the ifcWall to host windows, doors and openings but you would be able to cut out openings by other means)
  5. Save as a .rvt model
Option 2: Link the IFC into the model then use the generated "[FILENAME].ifc.rvt" (created in the same folder as the IFC file)
  • The elements in this model would be noneparametric directshape components.
  • They would have the relevant revit category (where applicable) but they would not be native components
IntYo189
Thank you for your help it worked.
IntYo189
