Any kind person can help to convert the attached .rfa file to a format that can be import into Inventor? Either .rvt or .step. Your help is much appreciated. Thanks in advance.
Regard,
CK
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Can't you load the family (RFA) into a blank project (RVT) and open the project file in Inventor?
Here's a SAT and RVT file FWIW:
Hi @barthbradley ,
Do you able to give another help? I have anther file file in .rfa format that need to covert to .step format.
Much appreciated if you able to help again.
BR,
Ck
See attached
